Thermostat location question.
vetplus40
My 5.0 Mercruiser I/0 has the thermostat located in the thermostat housing instead of in the engine block. Is this due to the "open loop" cooling aspect regarding coolant flow, or for some other reason? Thanks
Don't know your serial number but most all thermostats are located in the thermostat housing, open or closed cooling.
All thermostats are located in the thermostat housing
Unlike a car, a marine motor is constant flow to the exhaust
vetplus40
Thanks Scott, that was what I needed. I looked at the manual coolant flow diagram in the service manual but some lines had dual flow direction arrows and I couldn't exactly follow along.
