Thermostat Location?
nscvol
Hey everyone... Needing to change the stats in my 77 115 Johnson... Having trouble locating them... This is a new boat to me and I'm not real familiar with this engine... Can anyone tell me where they are located? Thanks in advance!
Daviet
Re: Thermostat Location?
If you stand behind the engine and look at the cylinder heads, you will see a hose from each head going to a housing in the middle of the engine. The thermostat is inside that housing.
nscvol
I thought that might be it.. It's the little solid brass piece... Thanks!
Vic.S
The diagram HERE may help as there are quite a few bits and pieces to the whole Venatherm and pressure control assembly. (Enlarge it fully with your browser magnifier to view it)
# 45 is the cover to which the hoses attach. #48 is the Venatherm. #54 is the Venatherm Valve and #55 the spring.
#47 is a check valve and #53 its spring.
Full parts list for this section HERE
