Re: Thermostat Modification V4
If they havn't been changed in 10 years, you definitely need to go through the whole thing. Relief valves, like clanton says, and new thermos accompanied by a thorough cleaning of the gunk and deposits accumulated over the years. The water pump needs servicing too, if that hasn't already been done. Use the whole water pump repair kit, not just the impeller. The heads should be hot, but allow you to hold your fingers on them for 30 or so seconds. If you can't, then they are too hot and something is wrong. May be deposits built up in other parts of the engine restricting water flow. This is a regular thing down here in the salt water, but shouldn't happen nearly as quick in continual fresh water use.
