Re: thermostat placement
Tdr<br /><br />The thermostat is behind the bubble thing on the cover plate on the cylinderhead, NOT where the plastic elbow fitting and hose for telltale sits, thats the exhaust jacket on side of engine. The sparkplugs both sits in the cylinder head, going through holes in the plate you want to remove. Note how the spring and grommet sits with thermostat, in order to put correct back in. You will need a new gasket.ONLY remove the small bolts, the big are headbolts, as said.
