Thermostat problem
Cinarli
I have a 1993 60hp 2 Str Mariner Outboard. When the engine runs for about 5-10min the buzzer comes on (constant buzzer, over heating). I want to know if the thermostat cover is correct on my motor. Because when I opened the cover I found that it has a poppet valve and the thermostat was missing. When I asked about this problem before I was told that there was 2 types of engines.
1 with thermostat only and the other with thermostat and a poppet valve.
Can somebody please help with this problem.
Engine Serial No. 0D243993 USA
Barnacle_Bill
Re: Thermostat problem
If there is a place for a thermostat then there should be one in there. The poppet valve comes into play at higher RPMs. When is the last time the impeller was replaced?
Cinarli
The impeller was replaced about 1 yr ago.
Yes you are correct, when I start going faster the buzzer will go off and when I go very slow or just idol, in about 5-6 min it will come on again. When the buzzer is on for about 5 min it stops peeing and smoke comes out. So I dont leave the engine on that long anymore. When I here the buzzer I just turn the engine off.
