My outboard motor(Johnson 115 crossflow) has two thermostats and to poppet valves.<br />It seems the thermostats work at low speed and the poppet valves open when the pressure increases at higher speeds. When the poppets open and let more water flow through the motor, the temperaure drops and the thermostats close.<br /><br />I was told that when the poppets valves open the motor temperature will be about 25 degrees above the temperature of the water the boat is in.<br /><br />Is this is correct? If not how does the cooling system operate.
