thermostat replacement 92 90HP force-gasket seal
dcar00
I am going to be replacing my thermostat. Do I need to or should I use gasket sealant or any other lubricant when replacing?
regards
dcar00
eurolarva
Re: thermostat replacement 92 90HP force-gasket seal
Get a thermostat cover Merc part number is 27-828319 cost is $1.25
dcar00
eurolarva,
I know how to put the thermostat together but I'm wondering if I need to put gasket sealant on the gasket when I do.
thanks for the reply.
eurolarva
The gasket is all you should need. If it does leak you could use a non hardening permatex. I dont like to use them however because it makes it a lot harder to replace it the next time.
dcar00
thanks eurolarva
