Thermostat
BOATRI
Need help with my 50hp merc.serial number is 6308153 can not find thermostat on motor. Water comes out the pee hole then slown down to a drip. Asalo need diagram of the motor .thanks.....
Ballymac
Re: Thermostat
Do you have 2 letters prior to the number?
Search this site for manuals. Good luck
Chris1956
Re: Thermostat
A lot of those Merc inline motors did not have thermostats. It sounds like you could use a waterpump rebuild.
Faztbullet
Re: Thermostat
As Chris posted that engine does not have a t-stat and needs impeller serviced....
BOATRI
Re: Thermostat
Thanks for the info already done a impeller rebuild just slow to the pee hole. Any ideas
Chris1956
Re: Thermostat
It the water slow to exit the telltale, or does it reduce to a drip? If it reduces to a drip that is an issue. Are you running on the flusher or in the water?
