Thermostate clogged ?
boat 1
Hello,<br /><br />IF i have a T stat clogged. would that cause the moter not peeing?. Because, the moter 2002,9.9hp 2strk. It seems to be too soon 4 impeller to go bad, Isn't it?. the moter turns over 4 a few seconds and dies, beause of no water comming out.<br /><br /> Any advice will be appreciated.
Laddies
Banned
Re: Thermostate clogged ?
A engine will not overheat that fast and stall so you have a differant problem, but a thermostat won't keep the telltale from working either, so it is either plugged or the pump is not working
Laotzu
If you have recently been in shallow water and sucked some mud into the pump, the pee line might be plugged. Try running a garden hose into the intake slots to see if water is making it's <br />way through the hose.<br /><br />Jerry
Bob H.
Try running a piece of wire through the tell-tale and make sure it's not plugged. If water doesn't come out after that pull the water pump. An engine won't overheat and stall for several minutes. If you've run in the shallows the impellor may be melted dragging down the engine.
