boating maniac
- Joined
- Jun 12, 2011
- 103
Ok I have a 1991 johnson 140hp, the model number is VJ140LEID. This engine has two thermostats. I replaced both. The engine still runs cold in cold water. Takes twenty 10-15 minutes of cruising before it kicks out of the cold start mode and starts to run nice and smooth. It will even go back into cold start mode where the rpms will go back up to 1500 or so in neutral if you let it idle in gear for a while say idle through a no wake zone for 10 minutes. Don't know why it does this or if it's normal, but I was wondering when installing the thermostats if you screw them in all the way until they seat on the diaphram? This engine has the plastic 140 degree thermostats. I read a post that says that the thermostats are supposed to screw and unscrew themselves to seat and unseat on the diaphrams. I don't know if that person was correct or not. That was a different motor.
