Thermostats WHY ???
fishon71
What is the reasoning behind putting thermostats in small outboards 8 -20 HP all they do for me is get stuff using in salt water.<br /><br />Do I really need to have one installed?
summers1996
Re: Thermostats WHY ???
Thermostats are designed to bring an engine up to opperating temp at a controlled rate. Once the opperating temp is correct the T-stat will keep it at the proper opperating temp. If the T-stat is removed or not closing properly, the engine will run too cool. If the engine is running too cool... the metal parts (pistons, cylinder walls, head etc.) have not expanded to their proper opperating deminsions and the engine will wear out very quickly. Starting an engine is the single bigest cause of wear over the life of the engine, cars and boats alike. Without a thermostat, it's like running the engine in start up mode all the time. Death will come soon. As far as salt water goes... Flush the engine better and keep a supply of T-stats arround, their cheap.
Texasmark
I bought a 3 year old used engine (freshwater use only). It overheated. The stat was stuck closed. I discarded it. I wasn't worried, outboard motors have been running for 40 years without them; why should I need it now was my reasoning.<br /><br />Well, things are different today; fuel makeup, leanburning engines (EPA) and all, so engines are more critical than before.<br /><br />I bought and installed a new stat and there was a marked improvement in the performance of the engine. Mine will stay. The thing was only $8 bucks on this site. <br /><br />For that price I could change it annually and not be bothered.<br /><br />Mark
deejaycee_2000
I also thought i didn't need one but realized it is there for a reason ...
WillyBWright
If you troll, you need it. Otherwise you get tons of brown foamy crud out of the exhaust.
