These guys are nutz!! (pics)
Dave Abrahamson
Hope no one sneezes! Sure wouldn't take much to snag a wheel and nose over real quick-like. REAL light touch on the stick! :eek: :eek: <br /><br />
<br />
<br />
JRJ
Re: These guys are nutz!! (pics)
Its all fun and games until a fish jumps :eek:
Reel Poor
I wonder how they handle a boat wake?? :eek:
JB
What are they trolling for? I don't see any rods.
bootle
What type of aircraft are they?
Dave Abrahamson
They are North American AT-6 Texans. AT for advanced trainer. The Navy called them SNJ's. In Canada they were designated Harvards.
Dave Abrahamson
Just seeing them do it is one thing...to do it in formation....... :eek: :eek: WOW
HT32BSX115
Any large wake wouldn't be good!<br /><br /><br />Actually you can "press" pretty hard on the water with the tires. With enough speed the water "presses" back with quite a lot of force(upward and of course, some drag which is somewhat negated by tire spin). It's similar to Hydroplaning on a flooded runway....above a certain speed (that's related to tire pressure) the plane is lifted completely off the pavement.<br /><br />The minimum speed required for total hydroplaning to occur is 9 times the square-root of the tire pressure.<br /><br />So if you have an airplane with say, 100 psi main tires the speed (min) would be about 90 knots.<br /><br />Those T-6's are going a bit faster than that!<br /><br />The T-6 has pretty big tires.... AT-6/SNJ main tire pressures were less than 40psi so it wouldn't take much speed to be well above the total hydroplaning speed.<br /><br /><br />All that said....I still wouldn't do it with a $200,000+ airplane! (someone would probably send a picture directly to the insurance company!)<br /><br /><br />Cheers, <br /><br />Rick<br /><br /><br />
Originally posted by Reel Poor:<br /> I wonder how they handle a boat wake?? :eek:
dogsdad
HT32BSX115...interesting!<br /><br />Doesn't the size of the tires matter? It seems like tires with a larger footprint would hydroplane more readily. Is that formula supposed to work for automotive applications too? If so, I would assume that driving much faster than about 50 mph on a well-drenched highway is flirting with disaster!
CN Spots
Aaaaa! Math! Run away!<br /><br />So is that why its called "on plane"? :D :p <br /><br /><br />spots
HT32BSX115
Funny....they always told me that size matters....<br /><br /><br />It really doesn't matter what size the tire is. It's pretty much dependent on pressure and speed.<br />(If you think about it, a very wide large tire will require much lower pressure resulting in a much lower speed to produce hydroplaning...so I guess size does matter)<br /><br />You'll probably notice that most roads are "crowned" so they drain well....but if there's standing water you'll get hydroplaning at about 50-60 mph in most cars. (36 psi) ---> 9* SQRT(36)= 9*6=54mph<br /><br />According to NASA it can happen in as little as 0.1" water.<br /><br />Here's about as good an explanation of different types of hydroplaning I've seen.<br /><br /><br /> http://www.mountainflying.com/hydroplane.htm <br /><br />There's a lot of info out there including a complete discussion I found on fluid dynamics and how it relates to Dynamic Hydroplaning. <br /><br />I think I'd rather go boating!<br /><br /><br />Regards, <br /><br />Rick<br /><br /><br />
Originally posted by dogsdad:<br /> HT32BSX115...interesting!<br /><br />Doesn't the size of the tires matter? It seems like tires with a larger footprint would hydroplane more readily. Is that formula supposed to work for automotive applications too? If so, I would assume that driving much faster than about 50 mph on a well-drenched highway is flirting with disaster!
Andrew Leigh
Those are South African boys. Have seen them fly before but not doing that. Here we also call them Harvards.
brother chris
I've never seen anything like that before. <br />Truly skillful!
Kiwi Phil
The Kiwi Air Force had them years back too. Called Harvards.<br />They also converted them to Crop Dusters. I saw one many moons ago, at Waipukurau airstrip. Pilot down the back, hopper between him and the engine.<br />Cheers<br />Phillip
