thickening agent for gelcoat
Salty Sal
Can I use ordinary talc powder that you buy in CVS , Duane Reade, etc. to thicken gelcoat?
imported_Curmudgeon
Re: thickening agent for gelcoat
Considering the cost of gelcoat, I believe I'd use that the manufacturer recommends. ;)
ondarvr
Most marine supply stores that carry resin will have products to thicken gel coat (and resin, the same stuff is used). Many things will work and all of them will give you different results, milled fiber will be lumpy but strong, cabosil (fumed silica)will be smoother and weaker, some types of talc can be used, but it's not that good around water, it can absorb it.
surlyjoe
cabosil is what your supposed to use in gelcoat, milled fiber is visible in the surface and talc/quatz (Q-cell) is too soft. cabosil is brittle but hard, gelcoat is not supposed to be structural.
