1977 Chrysler 75hp outboard motor (model: 757 HC).
I figured I would use the proper terminology this time. It is obviously not a whatchamacallit. Man I really need to order a good manual so I don't have to ask what something is every time, but until then...
On the starboard side of the engine there is some linkage that is connected to the carbs and runs down where it connects to another portion of linkage which runs back up and is somehow connected to the starter. Not sure what it does. I moved the throttle back and forth and it is not it, howver it does run close by the throttle linkage.
The reason I am asking about this is where the first piece of linkage runs down, it connects to the other portion on some sort of pivot before it runs back up towards the top of the starter. Well... where the other portion of linkage attaches it is connected by a black rubber/plastic joint which allows it to rotate on the pivot point. This piece is old and broke and the previous owner wrapped it with wire to hold it together. I don't like any kind of rigging like that because it could one day cause me to have to paddle my boat back to shore. Not my idea of fun when it could have been prevented by replacing what looks to be a cheap part.
This sounds confusing
but if anybody has a clue what I am talking about I would appreciate some words from the wise.
Thanks
Thanks
