think i will have to start over?
ohio river rat in KY
workn on a full rebuild and just got the transom in and fiberglassed in....just cut the key hole and drilled the plug hole yesterday and called it a day....and 2day it rained all day hard at that, and i had not got around to treatn the key hole and plug hole and it got soaked...so should it be ok or think i need to start over? or how can i dry it out? if got to start over its 2 sheets of plywood and around a gal. of reasin and fiberglass..:facepalm:...i so need a garage :facepalm:
oops!
Re: think i will have to start over?
nope.....no need to start over....
just take a big honkin fan......and blow air over the key hole cut out.
let it dry for a good two weeks......if you can add heat.....all the better.
next time.....cover the boat !
thinks for the good news....yep i took the lazy way out, been keepn it tarped up but was a long pretty day, just thought 2day was going to be the same, was going to finish it up this morning,did not think to check weather and it came a down pour. getting ready to get the fan out and u think a heat lamp will work to help out to....thanks again
oops!
when the surface water is dry....to speed things up a tad....wet out the water with acetone.....it will suck the moisture out of the wood
