Re: Thinking about going from aluminumto stainless???
JMO....without knowing your drive gear ratio, your WOT range seems to be on the low side for a 19p prop. I'm running a 3 bld alum, 14 1/4x 21p 20 ft, 4.3l, alph I gen II, WOT at 4900 and 44 mph (gps), but that is with a 1:81 ratio. My engine WOT range is 4400 - 4800. That puts me at the top of the range (which i like it to be). If I were to go down on pitch, I would be over -revved for WOT. In your case if you went up to a 21p you wouldn't even be running at your MINIMUM rpm range for it would lower your rpms even more. I would try out a 17p and see where your WOT rpms land up. But again a 17p prop just to get to your high end of WOT range sounds odd.
For the alum to SS, wouldn't worry so much about hitting objects as most the hubs they make these days for SS props act as the same for the alum ones (the hub will go before anything else), unless they are a fixed hub. From experience of friends, they have claimed to get more top end speed with SS, as well as better bite/grab than their alum props. I believe in...you get what you pay for. Oh yes, it would be nice for me to afford a Merc Rev 4 SS (at aprx $500)...lol. But seriously, I have an alum and its been good to me, I am going to another alum (just b/c my budget), 4 bld though for better mid range and cruising speeds. Bottom line is it's up to you and what you can afford. I've yet to hear people that went to SS from alum regret it and what to go back to alum. Again, JM2C.
