Re: Thinking about re painting my outboard
Redid my boat and motor this winter, I stripped mine to metal and started over, alot of work but it came out really nice.
On the hood you just want to scuff the paint, no need to tear it up, all you need is something for the new paint to stick too, my decals weren't too bad so I just taped them off.
I work in a body shop part time and we use a Scotch Brite pad and that is all so I would stay with 320 or smaller so you don't see scratches when you are done.
As for the motor make sure the base paint is still stuck to the motor, mine looked okay but came off in sheets in spots, ended up using a paint scraper to get it off, the rest I sanded with 320.
I used Duplicolor I got at Autozone, real close match to factory blue,I have an '81 50 Evinrude.
Make sure you use etching primer on any bare metal and yes you can use that on parts that are still painted.
With paint the end result is directly related to how long you spend on prep, the difference between a $300 and a $3000 paint job is about 100 hours, everything else is the same.
