ShoestringMariner
- Joined
- Apr 18, 2015
- 1,605
I’d like to change my controls from the Johnson/Evinrude OMC control box that mounts on the surface of the interior panel for something nicer looking.
I would like a cleaner looking style where the throttle box is inside the panel and all you see is the gear selector / throttle, OR If that proves to be too complicated I’d like to go with a more modern OMC control box/throttle. You know the dark gray type that looks more modern than the old white Johnson control boxes. This will be for a 1995 Evinrude three cylinder 50 or a 1990 Johnson 70. I have not decided which I’m going to run yet
If I go with the throttle gear selector only, and dash controls, I understand that there is a wiring harness that goes to dashboard controls.
So my question is what do I need for dash board items; tachometer, start stop off switch, anything else?
If I choose the more modern looking surface mount controls/throttle/your selector, where could I order one? Are all the late model controllers compatible with the early/mid 90s motors? There’s an ocean of them on the Internet. But I haven’t got an idea which ones are good which ones don’t work. Lots of no name stuff…
Thank you in advance
