Ruggybuggy
- Joined
- Sep 18, 2009
- 114
OK, I removed my old bilge pump to install an automatic bilge. Confirmed that the new pump is working by jumping it to a battery, float and manual override works fine. Install the pump and put the switch to auto and the pump starts to run. Put the switch to off and it stops. Put the switch to manual and it runs as expected. So I assume that something is holding up the float on the pump. I remove the pump from its retainer leaving the wires connected. Pump looks fine. I turn the switch back to auto and the pump doesn't run in the upright position. Turn it upside down and the pump runs. I assume that the float must have been sticking so I decide to put it back in it's retainer. As soon as I start to get down to the retainer the pump starts to run. WTF. Then I realize that my livewell pump is within an inch of the bilge location. If I move the bilge close to the livewell pump it turns on. Move it away and it turns off. This is keeping the bilge in a upright position. What the heck is going on? This doesn't make any logical sense to me. Forgot to mention that the livewell pump is off and I even disconnected it from it's power source.
Help!
Help!
