tallcar
- Joined
- Jul 20, 2002
- 143
Alcan this message is in reference to a previous post of mine in which you and others responded to my question of where to get carb float for '49 Johnson 5 hp.<br /><br />I tried the site that was mentioned, to no avail, then read your post( Alcan ) on how Chinewalker had used in the past a Merc float.<br /><br />Well that worked, I used a specific float out of a '46 Merc 3.2 horse that I ordered for said motor. Ordered from www.oldmercs.com This float is modified specifically for the 3.2 horse. What I had to do was make sure the float would float and lower to the correct level to attain the desired results. I pushed the float down far enough the the needle would seat. Worked the first time, I also found that the float fit very snuggly on the needle therefore requiring no attaching mechanism. Motor starts first pull, and now no gas overflowing thru bowl vent
<br /><br />anyway, thanks for a great piece of advice. My "customer" is now very pleased<br />
