This is what I got so far....
Newbie@boats
I took a picture of what I am doing to change my seals in the water pump to try to fix my problem.
I ordered my thermostat and gasket today.
In the picture #1 has to come off which needs to be pulled off to take the water pump cover off I believe?
#2 Is where the weep hole where the water was pouring out off.
#3 Is the cover that needs to come off to acess the water pump and change the seals?
Just want to make sure I am doing this right, or theres something I am doing wrong, or something does not need to be done.
Any tips or advice would be great, you guys have been lots of help so far!
Bt Doctur
Re: This is what I got so far....
Review the section in the Merc manual for seal replacement
1 comes off and the stator must be removed
3 No, this cover comes off to remove the impeller vane, then the main timing case cover is removed .If the cam is grooved ,it should come out for Speedi-Sleeves
This link explains the procedure
http://www.sterndrives.com/470_coolant_leak.html
BUT anti-freeze should be coming out , not just water
