soggy_feet
- Joined
- Oct 10, 2009
- 713
There is a question at the end of this, bear with me, I'm a storyteller.
A couple of years ago I moored my houseboat in front of this ladies house and paid her half of what the marinas were asking for a mooring. During my time there
I demonstrated enough boat mechanic skills to impress her and after buying a 95 Bayliner 3.L this year, she called me to ask if I'd look at the WOT stalling issue she's having.
It took no time at all to realize that I could feed the SHT forum for a year with stories about her unless I drill some basics into her head.
Garboard drain plug needs to go in more than hand tight..
Back the trailer far enough into the water to float the boat on or off, don't power load, OR UNLOAD.
Whether there's a no wake sign or not, WOT right off this particular launch is a terrible idea, since it's 3ft deep on average for about a 1/4 mile until you're out of the cove.
So I get the boat out to open water, open it up, realize that it's starving out wide open, and if you don't back off the throttle, it'll stall. If you don't start it right back up, it floods.
Pull the flame arrestor off, and gas is pouring into the intake manifold with the engine off.
Ok, so the boat sat with old gas, carb is gummed up, not flowing enough on the top end, can't stop flowing at the bottom end. Back to the launch we go.
I tell her how much the carb rebuild kit will probably cost her, tell her I'll charge her $20 for the work since she helped me out with the cheap mooring for a few years.
Get back out to the boat to pull the carb 2 weeks later and I see that the prop is now trashed. So the boat is limping, but she's determined to use it anyway.
I tell her she can't run the boat like that, it's not worth the potential (additional) damage it'll cause. I tell her what her prop repair and replacement options are, and she tells me that she'll get the prop fixed in a couple of weeks, but could I please finish the carb so she can take her boat out.
I reiterate that she's liable to cause some expensive damage running with her 14-1/4" prop at about 9" on the diameter, she tells me she'll address the prop next week, and she won't go far with her boat.
So, I try to explain it in car terms. She's got flat tires. You don't drive on flat tires because you're not going to get very far, go very fast, and you're probably going to do more damage. She tells me that she "didn't know it played that big of a role", and then asks how much damage she'd do if she just took it out for one weekend.
Sweet baby Jesus...
So, I'm re-installing the carb today. It'll need to be tuned on the water. I tell her that the carb is going on today but that I'm not making any attempt to do anything more than tighten down the bolts until she addresses the prop, or tells me to.
She's still pushing to run her boat tomorrow, and take care of the prop next week.
I really don't want to take all her money, but I haven't been able to convince her to do it right or not do it at all.
So, how would you handle this situation going forward?
Part of me wants to do her a favor and close down the idle mix screw and idle stop, and leave the electric choke disconnected. She'll be disappointed when she tries to take her boat out tomorrow and it won't start, but not as disappointed as when she sees the quote to replace all the bearings and seals on the prop shaft.
When I meet her this afternoon, I think I'm going to present a quote for a lower unit rebuild in addition to the $90 bill for the carb rebuild. Next time she won't get the almost free labor. I'm hoping that she understands the numbers even if she doesn't understand the explanation of what will happen if she tries to shortcut on boat repairs/maintenance.
Sweet baby Jesus...
