HeavyObject
- Joined
- Aug 26, 2007
- 82
Just trying to sort out some issues. This is the first boat over 14' and 10hp I have owned. Boat info is in sig.
Runs ok set in this hole, but will cav/vent in semi hard turns. Cavs/vents easy in the two upper holes going strait in rough water. Looses 3mph in the lower holes as the bow is down.
I assume I have the black bar on the cav plate? The center rib is around 1" below the plate
Side view.
Fuzzy shot from further back.
Needs a new prop but I need to get the tach working first. Current prop is a 13 1/4 x 17p. I can't drop the engine any lower without notching the transom, so does it look like it's low enough? Transom height is around 21 inches but I can't get an accurate measurement with the engine mounted. Comments or suggestions?
Side view.
