This noob needs help!!!!!!!!!!!!!!!!!!!!!!
Crazychris40
HI GUYS I HAVE A 92 200XP EVINRUDE V6... EVERYTHING I READ SAYS A CONSTANT TONE MEANS OVERHEAT.. my boat started doing this after a full day of flawless fishing, while i was trying to trailer it the constant tone started. the pee stream was strong and cool.. the only way i could get the tone to stop was when id squeeze the fuel primer bulb.. it would run at idle for 15-25 seconds then start again... squeeze the bulb and it stops hmmmmmm overheat not really constant tone = :confused::mad::confused::mad::confused::facepalm:fuel delivery maybe?????? help guys i ordered a new vro if thats not it id like to return it before i use it!!!! at 400 dollars !!!!!!
Joe Reeves
Re: This noob needs help!!!!!!!!!!!!!!!!!!!!!!
You squeeze the fuel primer bulb and the horn stops sounding = Fuel Restriction between VRO and fuel supply!
(VRO Horn Warnings)
(J. Reeves)
NOTE: I retired around 1991/92. Possibly some of the later V4 engines and others may also incorporate a fuel vacuum switch that would enable a fuel restriction warning to sound as mentioned below, an unknown factor to myself.
1 - A steady constant beep = Overheating - The V/6 engines, possibly some others, have a fuel restriction warning which is also a steady constant beep.
2 - A beep every 20 or 40 seconds = oil level has dropped to 1/4 tank. (Late model engine = Every 40 seconds)
3 - A beep every other second = VRO failure, air leak in oil line, oil restriction, (anything that would result in a lack of oil being supplied to the engine).
NOTE - If the warning horn is the black plastic (overpriced) three wire type horn, the warning horn should beep once when the ignition key is turned to the ON position. If it does not, it is either faulty or someone has disconnected it (a stupid move!). At any rate, if it does not beep which indicates that the horn is non functional, find out why and do not run the engine until the problem is corrected.
(Fuel Anti Siphon Valve)
(J. Reeves)
Many of the later OMC V/6 engines incorporate a fuel restriction warning via a vacuum device attached to the powerhead. If the engine overheats, or if you have a fuel restriction, the warning is the same.... a steady constant beep.
NOTE... Only the V/6 & V/8 engines have the above "Fuel Restriction Warning". The warning horn will not sound on the other models.
The fact that a engine is not overheating, but the warning horn sounds off with a constant steady beep, and that the rpms drop drastically would indicate that the engine is starving for fuel due to a fuel restriction. Check the built in fuel tank where the rubber fuel line attaches to the tank fitting. That fitting is in all probability a "Anti Siphon" valve which is notorious for sticking in a semi closed position. It will be aluminum, about 2" long, and the insides of it will consist of a spring, a ball, and a ball seat. If this valve exists, remove it, knock out those inner components which will convert it to a straight through fitting, then re-install it. Hopefully that cures the problem.
The above procedure will cure a restriction problem with the anti siphon valve as stated. BUT, it may also allow fuel to drain backwards to the fuel tank when the engine is not running (siphoning backwards) due to the fact that the carburetors/fuel pump etc are higher than the fuel tank. This condition is not an absolute as the valves in the fuel primer bulb usually prevent this backwards siphoning problem. However.... if this does take place, the cure would be to install a new anti siphon valve.
Crazychris40
thank you mr reeves all great info... if im understanding in your opinion from the novice description ive given. the problem is occuring before the vro??? hoses/ anti siphen etc.. or could it still be the vro??
Joe Reeves
The VRO would be functioning properly with great suction action. If not overheating, the problem would be a fuel restriction and is usually a faulty Anti Siphon valve as I stated above..
archcycle
You might want to check any in-line fuel filters or fuel/water separating filters.
