Uncle Daddy
- Joined
- Dec 5, 2004
- 5
Yamaha 1999 C115 pre-mix carbed engine. Motor suddenly started running rough recently...it idles and runs (not under load) smooth enough but coughs occasionally and blows a puff of smoke. I replaced the spark plugs, installed new fuel filter cannister (no water), serviced the fuel filter at block, installed a new fuel pump (that seemed to help a little but not completely). Here's the easy diagnosis clue. Starboard bottom plug is more DRY and black...all three other plugs are tan and damp with fuel/oil mix(normal appearance). I switched the coil on this cylinder with the one above, but the lower plug continues to be significantly darker. If this is a carb/fuel gum problem, then stabilizer really doesn't protect you all that well because I use it religiously and I don't let it sit more than a month without running, usually every two weeks.
