Salty Tricks
- Joined
- Sep 28, 2004
- 161
I 've posted before and thought it was solved but...
1991 200 hp Rude. I replaced the Rectifier with an Ebay purchased used one. Tach is a VDO. Dip switches are set for 12 pole. I get 12+ DC volts on the purple wire at the gauges. I have continuity on the black wire to ground. While engine running I do not have a negligible AC voltage reading from the grey wire (mV maybe ...certainly not 5 to 7 volts as I believe I should have) The gauge did register a rpm reading last week although it was erratic, Now I have nothing...pegged at zero. I tried another tach...nothing. I am certain the motor is charging the batteries as I have a Xantrex Link 20 battery gauge that accurately tracks voltage and amperage used and being put back in. At WOT I am registering about 25 amps plus going back into the battery.
What am I doing wrong?
