bobothewizard
- Joined
- May 8, 2007
- 42
I have a '93 Evinrude 90/65 jet and i have a heck of a time getting it to start. It will start after a little bit with the high idle all the way engaged but the problem with jets is the water is still pumping even when idling and a fast idle makes the boat go forward fairly fast.
I have changed the plugs out and ordered/recieved the proper carb rebuild kits but i just dont have enough nerve to pull the carbs off. I have a mechanic book that you can purchase but im fairly nervous to remove them.
Anything else that you guys can recommend besides pulling the carbs off. I think if i pull them off i will not be able to get them adjusted correctly. If it was one carb that wouldnt be too bad but this has 2 carbs with a linkage.
By the way, the boat runs great once its started but even after it warms up once i go to restart it again i have to put the high idle back on to start the engine again.
As always guys, thanks a bunch for the help its greatly appreciated.
