This weekend I'm taking on upholstery
jenn_8675309
misc. forward trim before (640x480).jpgmisc. forward trim after (640x480).jpgsofa cushion cover 2nd attempt (640x480).jpgsofa cusion cover tuck vs. sewn (480x640).jpg20130720_103851 (640x480).jpg
Could't get on the boat this weekend to work on the flooring, the fiberglass guy is fabricating the new cabin steps. Progress!!!
So, I decided to take an attempt at upholstering the sofa. I have made an ottoman once before, but that's the extent of my experience. I bought my fabric and thread on ebay, a navy blue sumbrella. With shipping it was just under $10 a yard. I reused the old foam, which was in good condition, and added a layer of 1 inch foam to beef them up a little bit. None of the cushions were square, which made for a complicated project. My first attempt was to just tuck and staple, which looked terrible. So, I dissembled them all and started over. This time I measured out the corners and sewed them, then stapled them to the base. It was a challenge, and they're not perfect but they have a more tailored look that I can live with. I should mention that I used a Brother sewing machine (with a heavy duty needle) that I bought from Walmart back in the early 90's for under 100 bucks. It had no problem sewing through the 2 layers of the heavy fabric. I also covered the back frame of the sofa. I carefully removed the old fabric and used it as a pattern, then sewed and stapled on the new fabric. I'm not going to attempt making the box cushions for the back of the sofa. I plan to use very firm bed pillows and make covers. Lastly I recovered a piece that is on the step up into the forward sleeping area, which I think turned out well. I still have the headboard in the aft sleeping area, and a few other miscellaneous trim pieces. But, they're still on the boat, and it's off limits until Tuesday.
Woodonglass
Re: This weekend I'm taking on upholstery
Use Photobucket for your Pics. Then click your user name at the upper right and click user settings. then click Albums in the upper left. Then click Customize upload options and select 1024x768. Once the pics are uploade use the IMG Code to copy and paste the pics into your iBoats thread.
jenn_8675309
I was able to edit the photo size, then it worked. I will try your suggestion next time, seems easier;-) Thanks!
redstrat
Nicely done :thumb:
83mulligan
Looks great. I have some of that kind of work in my future.
WillyS86
If you have really old foam you can use a steamer to revitalize it. It will pop the corners out so it fits better
jenn_8675309
Thanks for the tip Willy, I just happen to have a steamer:)
