Well, did my research and thought I knew what to expect with the purchase of my new prop. I was sooooo wrong.
So I have a Tracker V-175 Combo (with 90hp optimax). (about 17' long, approx. weight 1500#) - add in 9.9 bigfoot motor, 5-10 gal of gas plus maybe 40# of random stuff)
My second trip out on the boat (still in the first hour of use though) I chewed up my stock prop something fierce (Black Max - 19p) To the point it looked like this...
I asked the dealer about it and he said it was fine to run (would not hurt anything) but may lower my top speed by a few miles per hour.
With the prop in that condition (with the boat as loaded above + 600# of people) I got:
putting that info into the mercury prop selector it suggested a bunch of props in the 19p range
but - I always hated the way the prop looked......
I recently replaced it with a 19p Laser II. (supposed to be for smaller deep-V boats as well as bass boats) I expected RPM to drop a bit (maybe 100-200 RPM due to going to stainless from Aluminum) and top speed to increase slightly (maybe 1-2 MPH - although I was secretly hoping for more due to the condition of my old prop) This is what I ended up with (boat configured as above but only about 400# of people)
Putting that in the mercury prop selector - it now suggests just 3 props. (black max in 21p, Laser II in 20p or 21p and a trophy plus in 21p)
Based on the chewed up black max I started with - this seems like way to much pitch, but seems about right based on the 19p laser II I have now.
Without trying a TON of different props, what do you all suggest?
Thanks for any help - A very confused,
Michael
- decent mileage.
- ok holeshot
- 25mph at 3600 RPM
- drop off plane at about 20mph or 3000 RPM.
- Top Speed at WOT was 35 @ 5400RPM.
- planes VERY fast. (much faster than the black max)
- Fuel usage seems to have increased but not enough time to know for sure
- falls off plane at 20mph (as before) but now at 3800RPM.
- 25mph is still a comfortable run - but now at 4300 RPM
- Top speed is now 34mph @ 5900 RPM.
Michael
