thread wear on prop shaft what is causing it?
dingbat
Looks like your typical splined shaft that has been threaded.
What am I missing?
briangcc
Top of the thread, from what I can see, looks OK. Bottom of the thread, towards the plain splines, looks like they're ground down. Hit something??
airshot
I believe the thread is deeper at the beginning and gets more shallow as it gets closer to the straight spline area. That is what I am seeing in your pic. Threading tools have a taper on the lead in, so when it threads that shaft, the leading edge with the taper is where the thread runs out.
Texasmark
Looking on the non threaded spline, left side I think I see a grayish discoloration at a 30-45* angle. Considering the angle where engine/outdrives are position when sitting in a slip in a marina, I'd suspect some sort of corrosion (worn out sacrificial Zinc Anodes) besides the obvious runout of the prop nut threads, from where the MIL quit cutting.
