Three to Four Question Again
tompass
I have a Solas 3 blade SS 15 1/4 X 17 prop on Honda BF225 with Key West 23 WA and turn 6200 rpm's with 2 people and 1/2 tank of gas. Top speed is about 48mph. With more than 2 people and/or with near full tank of gas, I seem to need a bit more stern lift and thus am considering a 4 blade SS prop. Question is should I drop pitch and/or diameter? What Solas prop or other prop would be recommended solution to gain stern lift and improve handling?
rndn
Re: Three to Four Question Again
4 blades will make a noticable difference in the stern lift category.
tompass
I do understand that stern lift will improve but some are also saying that it comes at a cost of increased drag and some clunking going in and out of gear. Trying to decide on pitch and am considering a Honda 16 pitch 4 blade. I could even stay with a 17 pitch 4 blade as I will likely loose about 200 rpm's which would bring be down to an acceptional 6000 rpm's at WOT.
rndn
It is not a definate that you will lose rpm's by going to an SS prop over an aluminum. SS doesn't flex as much but it also cuts through the water easier.
tompass
I should have been clearer in original message. My Solas is a SS prop.
jay_merrill
Many find that the extra blade will drop rpm by about 100 for the same pitch. Going from aluminum to SS may provide some changes too. I just went from a 3 blade Michigan Match 15" pitch to a 3 blade, cupped, SS PowerTech 15" and picked up 100 rpm.
Try to find a shop that will let you try a couple of used wheels before you buy. While there are some generally accepted rules of thump about prop changes, I think a bit of trial and error is valuable before plunking down 300 - 400 hundred bucks on a new prop.
tompass
If all that would be lost going from cupped 3 blade SS to 4 blade SS is 100 rpm's, I would likely stay with 17P as I easily hit 6200rpm's with 3 blade. Still concerned with having heavier blade and affect on clutch dog shifting in and out.
tompass
Has anyone used a Michigan Apollo SS 4 blade prop? There appears to be a great deal on a 4 blade 16 pitch SS on Iboats.
