Hi
I know three vs four blade prop performance had been discussed forever but here it is again.
I have an 18.5 Stingray with a 130 hp four cylinder Merc. inboard. Normal pleasure riding the boat performs fine. Top speed in the mid forties. The prop is an alum. three blade 14.5 X 19" pitch.
( A chacteristic of the boat is that you have to run it with the trim all the was down all the time no matter how it is loaded. I don't know if this is normal for this boat or not. If anyone has one and knows please post. )
My question is this.
I want to improve the hole shot, when trying to pull a slyier out of the water Currently the boat does not perform well. The engine appears to ramp up ok but the boat takes a long time getting up to speed. Should I go to a 17 " three blade, a 17" four blade or would a 19" four blade increase the pulling power while keeping the top end speed.
If the 19" would perform well I would not have to change props for pleasure cruising.
Thanks RMC
Thanks RMC
