Re: Three way switch
Thanks also rob, helped me in figuring out how to check for any continuity for my switches. I have no bow nav lights currently, bulb looks ok. Switch housing is broken (cracked) but the tip still lights up. This long weekend i'll be taking a look at the socket to see if thats the problem instead. But I still need to order 3 new switches regardless.
Also had a question, to check for current off the switch to the bow socket, would I just set my multimeter to DC mode, put the positive on one wire and the negative on the other wire and then flip the switch? If I happen to get a reading then I assume that means there IS current going up to the socket. If there is no reading, then I assume its either the switch or the wiring that is bad. So then if there is current, but no continuity, then I have myself a bad socket (or dirty connections).
