G'day Everyone,
Subject to survey, I am about to purchase a 23' wooden boat which is powered by a 4 cylinder Diesel engine. The boat is 1950's vintage and the hull, deck and Cabin/cockpit area are all constructed with Marine Ply.
I intend to have the boat put on blocks in my backyard so that I can work on it. Apart from stripping/sanding the hull and repainting the restoration will involve replacing the entire deck area and cabin. This will be my first project boat and as I intend to make some changes to the cabin size and it's interior I am going to need advice on a few things before I even buy the boat.
1. Could someone tell me if it is ok to take a plywood boat out of the water for whatever length of time it will take me to restore it. Is it damaging to the plywood to let it dry out?
2. I am told the boat has a 3" wide keel and that I will have to keep it wet when I work on the boat. To achieve this I was told that I should keep a couple of inches of water in the bilge and this will keep it wet. Does this sound like good advice?
3. When replacing a cabin/cockpit on a boat how do you know if what you are building is not to heavy for the boat and if it is in the right position? What I mean is - if the new cabin is built using a heavier timber or if it is built
too far forward or aft then would this not upset the balance of the boat and how it sits in the water? If so how do you determine the correct dimensions and position?
Any advice on these matters will be much appreciated.
