throttle adjustment help
tommythecat
do i need to adjust my throttle cable if i turn the idle screw up a bit? my boat runs well but dies when i put it in gear unless i idle it up a bit. do i need to set the carbs it is a 71 chrysler 85hp outboard so there's three and the linkages are lined up well. any help is appreciated.
Dlubke
Not sure I follow, Are you talking about the adjustment screw on the linkage tower? If you adjust that to change idle you don't need to adjust any additional carb linkage.
jerryjerry05
Figure out where the towershaft is???
Then at the bottom of the shaft is the idle adjustment.
Screwdriver and a 7/16 wrench.
If that doesn't seem to work??
Then one of the top posts in this forum is a post by FrankA
Called a link and sync.
Read it anyway it has good info.
