Throttle Body question
Chaparral220
New to the forum so thanks in advance.
Silly Question that I should probably know. Do you need to rebuild a Throttle Body Injection the way you would a regular carb? Can you just spray carb cleaner in it? Should I? What is the preventative mainenance for one of these? Or is there? I do the standard additives, water separation filter, and stablization. It is a 5.7 EFI OM series.
I had a small Chevy pickup and I never did anything to that TBI.
Chaparral220
Re: Throttle Body question
So there no parts to replace or inspect? The two injectors seem to be doing fine.
TilliamWe
Banned
It should not require any maintenance. Just like your truck, cause it's the same exact system.
I "believe" that the screens in the injectors can be removed and replaced, but in 10 years and 800+ hours, my 97 Chaparral with TBI on it never needed any service. Other than the injectors, the throttle plates are the only other parts, and they don't wear out. I supposed the throttle plate shaft could wear out, but I have a 90 Model van with the same TBI and it's all perfect.
It's a very simple system, no need to mess with it.
Stabilizer when storing is always a good idea, though.
