I am seeing a problem with my throttle cable/ shift cable. Not sure on the proper term. When I pull back from WOT or anything other than idle I get to neutral and the motor is still engaged in gear. I actually have to go slightly into reverse to get the motor to go into neutral. It does the same going from reverse to nuetral. Rarely it will go into neutral by itself. But more times than not I have to compensate for it. Can this be adjusted or do I need new cables? It is on a 1982 Johnson 140 with OMC handle that I believe to be original.
