Re: throttle cable linkage question 90 hp evinrude 1981 v4
I dont believe there is play there. I just went thru the full Link/Sync including those cable adjustments and dont recall any play once setup and mounted.
it isn't loose at the clamp down. the loose play is where the black tube (orange line) is sliding over the gold rod about a 1/4 inch when you move the throttle lever.
