For my 1985 Johnson 90, the manual indicates that the throttle cam mark should be in the middle of the cam follower (roller) when the "first embossed mark on the cam contacts the cam follower". What has never been clear to me is whether or not the cam and the follower are supposed to touch when the engine is at idle. What got me thinking about this again was a post here from last week where someone said that the timing should advance before the butterflies open. The way I have my sync set, that wouldn't happen, as the cam is against the follower, at the mark, at idle. Any increase in throttle moves the plates immediately. My question is whether or not the cam and follower should be touching at idle.
Thank you,
-E
Thank you,
-E
