throttle control diagram
ddzhere
I have a 87 ebbtide dynatrak that currently has a 97 evinrude 90 hp on it. I believe my throttle control is more around late 80's... Does anyone know where i can find a parts break down for it. It has alot of play in the idle and throttle control and I'm hoping to be able to rebuild it. The control is is a johnson.
belairbrian
Re: throttle control diagram
FWIW,
I have the same throttle control as in the link. I had mine apart this weekend as my fast idle lever was very sloppy and moving side to side.
I found the screw (#82) in the diagram was loose. You can't see it with the throttle lever (#38) installed. Also found some wear on the lockout lever (#67) where it goes through the slot in the lockout cam. There is a lip and part of it was worn down.
Thightening the screw (#82) took the play out of the lever.
