Throttle Control maintenance
cloumar
Is there any maintenance to do like cleaning or lube the shifter/throttle arm - it is a Quicksilver - is there something to lube inside ?<br /><br />Plus what is that friction adjustment knob in the front - I don't see much difference if I turn in or out this knob.<br /><br />Thanks<br /><br />Smoky
rickdb1boat
Re: Throttle Control maintenance
Hi smokey<br /><br />Once you clean it up and lube the pivot points of levers and gears in the control, it should be good for years. Use grease on the pivot points of arms and levers.
