I have an OMC set of controls on my boat. It is a single handle for forward and/or reverse, and it also has a small handle that you lift up on for starting the motor it says "fast idle" on it. It is stuck in fast idle. Did not have any problems in the past since I bought the boat. It has new cables bought last season and installed by a OMC dealer. I can push the fast idle lever back down but it seems to not be connected to the gas cable any longer. I can work the cable by hand at the motor end and it idles good, but as soon as I go forward and wide open throttle, then I back down again, the idle is way up there again until I bring it down by hand at the motor end.
What can I expect to see if I take the control box apart? Thanks!
