Throttle Gradually Slows ?
Chrsamss
Hello,
I have a 19 DC, the throttle handle will not stay in the position that I leave it. I always have to keep a hand on it or it will gradually slow down.
Is there a way to tighten the handle / cable so that this will not happen?
Thank you for the help
This_lil_fishy
Re: Throttle Gradually Slows ?
First off, unless you are at idle in nuetral, you should always have a hand on the controls. That said, it is an odd problem, we would need more info, engine type/manufacturer/year/HP and control type for starters.
Ian
_chris_
My old Glastron did that, I found out my grandfather put a return spring on the carbs for whatever reason.
Chrsamss
it is a 1992 19DC Sea Pro It has a 115 Merc also a '92
The controls are original
Thanks
Bart Sr.
A friend in 1980 had an 18ft Baja with a 115hp Merc.The throttle control was set up to return to neutral for safety reasons.That being if the operator was disabled or thrown out the boat would come to a stop hopefully before hitting anything or anyone.
Splat
Look for a knob or lever on the controll marked throttle tention, or throttle friction.
If you have one tighten it a bit.
Bill
JoLin
Bill
+1
my '97 Johnson had a friction adjustmant knob/screw at the rear of the controller box. If it was set too loose the throttle wouldn't stay put. If your Merc doesn't have one I'd suggest there are worn parts in the control box...
JoLin
Bill
+1
My '97 175hp Johnson had a friction control knob/screw at the rear of the controil box.
Silvertip
Most side mount controls have a knob on the front of the control box, or a screw accessable through a hole in the front or back end of the box. This is the throttle friction adjustment.
