Throttle Handle Slipping
jakenjulie
Hey Guys,
I have a 2000 Johnson 200 hp Ocean Pro on a Hydra Sports cc. The throttle will not stay in place when cruising and is hard to hold steady in waves. If I take my hand off of it, it goes back to a fast idle. The throttle assembly mounted to the console does not have a name or any markings on it so I don't know if it is std equip't or after market. I had a mechanic look at it and he said there was no friction screw adjustment to tighten it up. Does anyone know if there is a remedy?
Thanks,
Jake
Daviet
Re: Throttle Handle Slipping
If you could post a picture of the control maybe someone could help you out.
pn
bungee..., take it apart somethings probably loose inside. usually a set screw on the bottom, go way down, look up on the handle pivot pnt.
