Pontoonfoon
- Joined
- Apr 28, 2010
- 69
I have an 08 Suntracker signature party barge.
the boat shifts out of neutral easy, but as you push the throttle foreward its fairly stiff.. much more so than any other boat ive messed with, and its hard to be smooth with it.. It is as though it sticks.. then slips then sticks...
coming back on the throttle is worse.. apparently there is something spring loaded in there because as I back it off from wot its nothing.. nothing then there is an audible *shunk* inside the throttle assembly and it goes from perhapos 4k rpm to 2.. I literally cannot throttle down from 4k to 3K it slips to 2 then I throttle up to 3.
disconnecting the throttle cable from the motor has no effect, the issue is in the throttle box.. HOW DO YOU GET IN THERE?
