I got in my boat the other day and found that my throttle/shift lever wasn't lined up in neutral (it was a little forward). So I tried to move it back where neutral is marked on the arm rest and it wouldn't move. I moved it forward and it felt like it went through neutral then into forward. It seems to have full range of motion going forward but reverse seems shortened. Does that make sense?
I backed the boat out from the dock and tried to go forward but it wouldn't go, it just reved up the engine. So I tried adjusting the shifting cables while on the water and I could get the engine to go forward but not reverse.
I think my kids might have been messing around in the boat and moved the throttle/shift lever out of position. But before I start trying to tear the control box apart I thought I would check here.
The engine is a 1977 Johnson 70 HP and what appears to be the original throttle/shift control box.
Where should I start looking?
The control box?
The shift cables?
The control box?
The shift cables?
