I just got the boat and motor 1986 85HP Force. The throttle linkage is not set right. how do i know you ask? well, when in neutral i can pull OUT on the fast idle button on the control / shifter and the throttle lever will only move about 1/4 way down. well even though it moves, the idle stays the same. which leads to my next question.....
Is there an online manual somewhere that i can purchase that has the procedure for re-calibrating the throttle linkage / shift linkage???
Thanks Guy's
This is my second outboard, so i hope to learn a good deal more about them.
Thanks Guy's
