Re: throttle linkage
The engine is 86 and it used the across the valve cover system which I cant use. I need the system from the 70's model 140. I'm useing the manifold from the 86 with a straight 180 elbow to connect to my factory pipe. And a merc carb. but I need the bolts, pivot, and linkage that bolts to the side of the manifold. As long as its for a manifold that doesnt have the bolt on carb mounting plate it should work. The parts from a straight 6 chevy should also work.
Also the mercury parts site sucks, It only works if your using an exact swap. It wont let you browse to find what you need unless you have the ser number. It needs a year and model feature as well.
