Throttle Locks Up At Control Box
moondok
I have a 1975 50hp Evinrude. Throttle and shift cables have been replaced and work great. No problems occur at the engine. For some reason the throttle lever randomly locks up. It has locked up in all three positions: forward, neutral, and reverse. To temporarily fix it, I can take the throttle box completely apart, pull the large black gear all the way out, put it back in, and reassemble everything. It will work fine for a couple of days then lock up again. This last time the throttle jammed, it was in forward and could move throughout all forward positions. This is the first time it did not lock up completely. It would not slip back into neutral. <br /><br />As this is a pontoon boat, I'm not crazy about the idea of paddling back to shore. Does anyone have suggestions? <br /><br />Stuff I know: the throttle lever itself is not loose or wiggle excessively; both the neutral switch and ball w/spring are intact; the shift and throttle levers that are attached to the cables appear to move freely when all is well; I can move the throttle and shift arms on the motor with my fingers<br /><br />Thanks to all who may have an answer!!
Joe Reeves
Re: Throttle Locks Up At Control Box
You may have one of the older white OMC control boxes that contains a shift lever within it. This lever will have white nylon teeth of which two of them (the teeth) have extremely fine edges.<br /><br />It has happened that the very tip of one of those teeth will chip/break and will cause the control box to jam. If one is not looking for that exact problem and the mention cause, it is quite easy to overlook.<br /><br />Email me at my address below and I'll send you a graphic of the part in question. I have a few left in stock if this is your problem and you can'r locate one elsewhere.<br /><br />If you contact me, be sure to jog my memory as to what the email is about.
Basscat 1
Like Joe said, replace item 95 on this web page and your problems should be solved.
moondok
Just to let everyone know, that part was the problem.
Basscat 1
Good, I am glad you got it fixed and posted back.<br />Feedback is always good.
That page worked for me too Basscat! Awesome resource, thanks a bunch!
