enginepower
- Joined
- Jul 5, 2014
- 260
Have a 1995 90HP 3cyl. Noticed that the top carb throttle plate doesn't open to full extent as bottom two which means this one is closed more at idle than other two which probably explains my uneven shaky idle. It has a slotted cam with screws to lock in place. What would be the procedure to adjust this? I am thinking loosen screws and let all of them close fully then tighten screws down? Also, what would be a good starting point for the fuel mixture screw (amount of turns from seat)
